Manitou
Feb 13, 2026Tutor
no software update available
I received a message from Netgear that I should update my MR6450 - Nighthawk M6 Pro mobile router as soon as possible. However, there is no software update available when I request an update through ...
- Feb 24, 2026
Thank you all for your responses and input. The update was rolled out today for my M6Pro. Patience is a virtue.
Manitou
Feb 13, 2026Tutor
Thnx for the feedback ! I am sure that the message is from Netgear.
https://view.e.netgear.com/?vawpToken=JSKBJI2VN6YUXL2ZKD3HE6PJ2E.10192
I buy the M6Pro direct from the Netgear store in 2023-01 , so it is not a device
distributed by a carrier!
Support from Netgear are also end.
- StephenBFeb 13, 2026Guru - Experienced User
distributed by a carrier!KevinLiT​ - Can someone from Netgear follow up?
