Manitou
Feb 13, 2026Tutor
no software update available
I received a message from Netgear that I should update my MR6450 - Nighthawk M6 Pro mobile router as soon as possible. However, there is no software update available when I request an update through ...
- Feb 24, 2026
Thank you all for your responses and input. The update was rolled out today for my M6Pro. Patience is a virtue.
jamesjhone7
Feb 24, 2026Tutor
Sometimes those update alerts roll out in batches, so the notification can appear before the firmware is actually pushed to your device. You might try rebooting the router, checking again after a few hours, or confirming with Netgear support whether NTGX65_12.01.54.00 is already the latest for your region. I’ve seen similar update-delay explanations discussed on small finance as well sometimes it’s just a staged rollout rather than a missing file.
- NairBFeb 24, 2026Guide
Yes I agree, looks like the updates are being rolled out in batches as mines arrived a few days back. I am now running on firmware NTGX65_12.01.74.00. Hopefully this will happen also for Manitou the original poster of the thread.
