Agis
Mar 12, 2020Follower
Old wm6.5 phone connection
Hello,
I need your help. I am trying to connect an windows mobile 6.5 phone but nothing works.
I see that my phone is connected but it cannot find any DNS . I tried manual and auto but nothing. Do you have any suggestions? Newer phones works ok but I need this phone for my job.
1 Reply
- Blanca_ONETGEAR Employee Retired
Hi Agis
Welcome to NETGEAR Community!
You mentioned "I tried manual and auto but nothing", are you referring to the IP address setting? To clarify, did you set static IP address and DNS address?
To compare, please try connecting the Windows Mobile 6.5 phone to different network and check if it can go online.
Blanca
Community Team
