seventz
Sep 02, 2022Aspirant
OpenVPN client "Server poll timeout"
Hello, all! I have a problem with the VPN connection to my network from Android. I use the LAX20 router. In the router settings I did the following: - Enabled DNS service provided by Netgear (noip...
michaelkenward
Sep 02, 2022Guru - Experienced User
seventz wrote:
Hello, all!
It is actually a 4G LTE WiFi 6 Router.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
