Sep 12, 2018Apprentice
OpenVPN Netgear LB 1120
Hardware: Netgear LB 1120 LTE Mobile Modem and TP-Link Archer AC 1200 WIFI Router T-Mobile: Prepaid Mobile Broadband This setup is freaking awesome and I am happy with the signal quality provided by ...
techmania
Sep 12, 2018Aspirant
It is very helpful while you traveling. It works very simply and you can easily set up to your system.
You can install VPN server and need to transfer to the right port of your router and your system run on your system. Check it hp touchpad not working for more info
96708
Sep 14, 2018Apprentice
FU up your mothers a. I asked for help and you post spam BS.
