Sep 12, 2018Apprentice
OpenVPN Netgear LB 1120
Hardware: Netgear LB 1120 LTE Mobile Modem and TP-Link Archer AC 1200 WIFI Router T-Mobile: Prepaid Mobile Broadband This setup is freaking awesome and I am happy with the signal quality provided by ...
chauhanmandis
Dec 17, 2018Aspirant
Hi i don't know much about the networking but i also faced the similar problem.
I doubt that you are running a DNS Server on your W7 Server .. so pushing this:
# can be pushed to clients, such as DNS
# or WINS server addresses. CAVEAT:
# http://openvpn.net/faq.html#dhcpcaveats
# The addresses below refer to the public
# DNS servers provided by opendns.com.
push "dhcp-option DNS 10.56.78.1"
;push "dhcp-option DNS 208.67.220.220"
will not work.
Try this instead:
CODE: SELECT ALL
push "dhcp-option DNS 8.8.8.8"
push "dhcp-option DNS 8.8.4.4"
Hope this helped.
You can reach advisors if still facing the same issues.
QuickBooks Enterprise Support Number
