trueluddite's avatar
trueluddite
ORBI - dropping WiFi
as you can tell by my name i am clueless, so respond to me as you would to a 4th grader.
ISSUE: for the past 24 hours we have been unable to maintain WiFi connection (i.e. 'net connections on phones, iPads, RokuTV keep 'dropping'). for example, try to access a website via iPad: 'cannot access because not connected' message appears. same with TV and phones.
REMEDIATION: re-booted modem/router innumerable times; re-booted devices innumerable times; walked through various 'pings' and other steps with cable company csr (we have a strong signal).
usually, when the connection 'drops', if i turn off WiFi (to the iPad, for example) and turn it back on, i will have access for a while; then it will 'drop' again.
we have the ORBI system referenced above, with the main router/modem on the 2nd floor, a repeater on the first floor and another in the basement. usually works great. devices using the network are iPads (2), RokuTV, iPhones (12 &13) and school Chromebooks.
i note that the lighted 'ring' at the top of the main router/modem is slow-flashing white; does that denote something is wrong?
any help will be greatly appreciated!
  • BTW: i just read through soe of the recommendaed responses to similar questions. each appears to be written in a language that i do not understand. if you have advice for me, please provide it in " disocnnect the white cable connected to the ..." or " go to 'Settings', drop down to 'X', do 'Y', then ..."
    i am that simple ... sorry.
    • michaelkenward's avatar
      michaelkenward
      Many questions are common to lots of devices but in this case your Orbi router is nothing like the "Mobile Routers, Hotspots & Modems" covered in this section.
      You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
      Orbi - NETGEAR Communities
      I will ask the Netgear moderator to move your message.
      In the meantime you could visit the support pages:
      Support | NETGEAR
      Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
      You may have done this already. I can't tell from your message.
      I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
