Alex-'s avatar
Alex-
Orbi LBR20: Apple PowerBooks don't see the WiFi network SSID
I am using the ORBI LBR20 with standard, out-of-the-box configuration. All of my devices can see the SSID and connect to the WiFi network, except my older Apple Powerbooks (I still use two of them) d...
  • FURRYe38's avatar
    Ah, So maybe not AES supporting which is possible. Try WPA and TKIP setting on the LBR?
