Alex-
Mar 25, 2024Aspirant
Orbi LBR20: Apple PowerBooks don't see the WiFi network SSID
I am using the ORBI LBR20 with standard, out-of-the-box configuration. All of my devices can see the SSID and connect to the WiFi network, except my older Apple Powerbooks (I still use two of them) d...
- Mar 25, 2024
Ah, So maybe not AES supporting which is possible. Try WPA and TKIP setting on the LBR?
Alex-
FURRYe38 wrote:Even if you set no security on the Orbi system, set to NONE, does anything appear on these devices? Re-enable after checking.
Thanks for the hint. After changing security from WPA2-PSK [AES] to none, the PowerBook does see the network. What does this tell you?
Mar 25, 2024Guru - Experienced User
