Nexus0391
May 09, 2024Tutor
Orbi NBR750 5G router
I have the NBR750 5G Orbi router and I cannot for the life of me get it to update the firmware even though the support site shows a newer version available. On my router, it's showing the last 2 numbers as .50 but on the support site it shows a firmware version .66. I have tried both updating through the orbi app, and manually by downloading the firmware to my PC then manually installing through 192.168.1.1 with no success. The router has also been factory reset but still nothing.
Sorry for the late update, took me a minute to get to these troubleshooting steps. It looks like it finally worked! I may not have been extracting before, I made sure to extract this time and the firmware is now updated. Thank you for the support!
what error does it give you when you try the update?
- It just tells me that the update failed to please check my file and that's it. Even tried deleting the downloaded file and re-downloading with the same result
A couple things.
1. are you making sure you extract the download prior to uploading it to the router?
2. maybe try going to the .63 or .64 version.
