Marco2073's avatar
Marco2073
Follower
May 03, 2026
ORBI NBR750 5gh cannot be disabled
I have an ORBI NBR750. I need to force the router to use only the 2.4 GHz antennas by disabling the 5 GHz ones. Even though I’ve done this, I still see some connected devices listed as connected to the 5 GHz band. I turned off the two satellites, restarted the router, but nothing changed; my iPhone is still connected to the 5 GHz band instead of the 2.4 GHz band. Netgear support doesn’t seem to respond to products that are out of warranty. How do I fix this? Also, the system tells me there’s a firmware update available, but in reality, there isn’t one. Is it possible to have all these bugs?
1 Reply
  • plemans's avatar
    You can't disable 5ghz on the Orbi's.
    Why do you think you need to disable it?
    What firmware version are you on?
