simkris's avatar
simkris
Our Aircard 781S has been adding to data usage without being online
For about a year now we have on several occasions watched the data usage count on our AC781S start increasing in huge increments, even when we are not on line. ATT has blamed the Aircard for this. We lost 5 gb of data this past week. Can there be a problem with the Aircard causing this ?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello SImkris
    Are you saying when the aircard is off you are seeing data usage on the plan go up?
    DarrenM
    • simkris's avatar
      simkris
      Yes I am PLUS I can watch it spin data away while watching it and not doing anything on line. It happened again today. ATT is not willing to help. They say it is the Netgear device that is having problems and it is out of warranty. This is has been ongoing for almost two years. WE have lost about 15 gb of data - two GB spun off this morning while I was trying to start my computer. No updates were loaded from other programs. I turned the device off and went to the ATT store and they again said it is the devices fault. When we turned the Netgear back on then about 1.5 GB came back. This is extremely frustrating that no one will give us a solution to why this is happening.
      • DarrenM's avatar
        DarrenM
        The data usage indicator should not be used for billing purposes. You should request a detailed data usage report from AT&T to see where they are using data. Legally, AT&T have to provide this report as they are billing the customer for the usage.
        DarrenM
