richardx73's avatar
richardx73
Ping times out
I need to find the latency from my home computer to my remoted 6100D gateway.   First attempt failed with "timed out", but I discovered that I hadn't enabled remote Pings in the 6100D security sett...
  • richardx73's avatar
    richardx73
    Jul 23, 2016
    Problem still exists.  Ping trace showed timeouts, but results didn't make any sense to me.  I'll try calling my SIP (Sprint).  They haven't helped in the past, but I'll ask them for an opinion.
    For the moment, I'll assume this isn't a Netgear problem.  My frustration continues trying to isolate and correct problems.
