Drester's avatar
Drester
Follower
Apr 15, 2019
Poor cellular signal fix
I have Poor to Fair signal strength on my new Nighthawk mobile router.
5 bars on ipads and cell phones.
Has anyone found the best cellular signal booster antennas out there for this device yet?
Thanks,
Drester
1 Reply
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi Drester
    Welcome to NETGEAR Community!
    If the reception/signal is low then we suggest moving the device to a location with clear view of the sky or consider purchasing/using external antenna.
    You can check this link for antenna suggestion.
    Blanca
    Community Team
