MOHAMED1992's avatar
MOHAMED1992
Follower
Jun 15, 2019
Poor WiFi signal
Why WiFi signal is weak is there setting to adjustment signal?! Or there’s problem in my device!?
  • plemans's avatar
    Would need way more info than what you provided to help you or determine these issues.
    1. What router are you using? Firmware on it?
    2. What speeds do you pay for? What speeds do you get over a hardwired connection? Speeds over wifi in the same room with the router?
    3. How large is your house?
    4. Building materials in your house?
    5. What devices are you testing with? wireless in them?
  • i am also disapointed in the MR1100 i get 1 bar with it. But if you put the extreme express AC797s next to it it get 5 bars of signal.
    Sugestions
