kevinpaynter's avatar
kevinpaynter
Follower
May 22, 2019
Port Forwarding Not working
I have recently purchased a Nighthawk M1 and this replaces my existing netgear router. The software with router has a port forwding area which I have openned however whenI check it is telling me the service is unavailable
 have no idea what I am meant to do, as Its open with old router if I swap it out but not new one.
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi kevinpaynter,
    Welcome to NETGEAR Community!
    - May we please know the exact model of your MR1100?
    - What is the firmware version?
    - Who is your Internet provider?
    Blanca
    Community Team
    • schumaku's avatar
      schumaku
      Looks like a Testra IP address.
      Using the same SIM and contract as before?
      Does your M1 have a public IP address assigned by the mobile ISP? If there was a contract change, you might have to request this again.
  • ArodiD's avatar
    ArodiD
    NETGEAR Expert
    Hi kevinpaynter ,
    The IP address that is showing in your screenshot looks to be a NAT'd IP from memory which will block ports from the network side.
    Can you check the APN settings on your old router to see if it matches with the MR1100.  I suspect your old router APN profile might be telstra.extranet and the APN profile used on your new router is telstra.internet.  If so, then create a new APN profile with telstra.extranet on the MR1100 and set it to be the default profile and it should start working for you.
    Arodi
    Community Team
