jbowlingknoxNG
Apr 29, 2018Aspirant
Port Forwarding on Nighthawk M1
Has anyone had luck with port forwarding on ATT wireless network. I have a panasonic security camera that I would like to monitor when not at home. I have done this before with ATT DSL but am not h...
JasonN
May 03, 2018NETGEAR Employee Retired
Hi jbowlingknoxNG,
Can you please check with your ISP and see if their network supports port forwarding for your device?
Please let me know. :]
- Jason N
jbowlingknoxNG
May 03, 2018Aspirant
The ISP is ATT Mobile. I have contacted tech support twice and was told both times that they do. At the second contact I inquired if the IP was public at the request of Netgear support and ATT said that the address of the mobile router was indeed public. When I pressed ATT and port forwarding they told me to contact Netgear support.
