intofx's avatar
intofx
Guide
Apr 16, 2018
Pre April Nighthawk and band 14 and 46
Will the pre April 2018 - version 6112B - AT&T Nighthawk get bands 14 and 46 enabled via firmware? I see that hardware is the same as the newer 6420B version.     I just bought a new hotspot but it...
  • ErnestTheGreat's avatar
    ErnestTheGreat
    Apr 19, 2018
    It seems like there is some confusion here about the models of AT&T M1 Nighthawk LTE Mobile Hotspot Router.  So I will try and explain the different SKU and the differences between them.
    Netgear has 4 SKUs for AT&T M1 and they are: MR1100-1A1NAS, MR1100ABS-1A1NAS, MR1100-2A1NAS and MR1100ABS-2A1NAS.
    Main Consumer SKU
    AT&T Business SKU
    Main Consumer SKU
    AT&T Business SKU
    Netgear SKU ID
    MR1100-1A1NAS
    MR1100ABS-1A1NAS
    MR1100-2A1NAS
    MR1100ABS-2A1NAS
    WPS
    Supported
    Not Supported
    Supported
    Not Supported
    USB tether
    Supported
    Not Supported
    Supported
    Not Supported
    Ethernet tether
    Supported
    Not Supported
    Supported
    Not Supported
    Ethernet Offloading
    Supported & Disabled
    Supported & Enabled
    Supported & Enabled
    USB thumb drive and SD Card
    Supported
    Not Supported
    Supported
    Not Supported
    1500/1430 byte MTU selection dropdown box
    Not Supported
    Supported & 1430
    Not Supported
    Supported & 1430
    Band 14
    Not Supported
    Not Supported
    Supported
    Supported
    Also the AT&T M1 does not support B46 only B14 was added to the 2A1NAS SKUs there will be no firmware updates available for 1A1NAS to support B14. The B14 needed hardware change to support FirstNet B14 properly that is why HW was changed. So I am pretty sure going forward the all the new units Netgear ships will be the 2A1NAS SKU units.
