mondofresh
Apr 30, 2018Initiate
Problem with LB1120
My LB1120 on Verizon has been working fine for the past 3 months. Last week the unit stopped working.
Here is what I'm seeing:
Solid amber power light
The green signal strength bars are lit...
JasonN
May 01, 2018NETGEAR Employee Retired
Hi mondofresh,
Is your device up-to-date with the most current firmware? Make sure you are connected to a wifi or in and area that has good connection before checking.
Below is the another way to do a factory reset.
https://kb.netgear.com/31171/How-to-reset-4G-LTE-Modem-to-factory-settings
Please let me know. :]
- Jason N
- mondofreshMay 01, 2018Initiate
Physical reset:
I have tried the "press reset for 5-seconds" and there is no resultant reset or status change. Lights continue to be lit as described in original post.
I have tried holding reset button for over 60 seconds.
I've tried press/hold during power cycle
When cabled directly to ethernet port with laptop, I am unable to get to 192.168.5.1. In fact, I seem to be picking up a 192.168.225.* address. Obviously I'm not able to get to default 192.168.5.1. I am, however, able to ping address 192.168.225.1. This IP doesn't seem to serve up the management UI.
So...it seems like this device is bricked. I can find no documentation that describes the solid amber and every other signal light illuminated condition.
- JasonNMay 03, 2018NETGEAR Employee Retired
Hi mondofresh,
I will PM for further assistance. :]
- Jason N
- JasonNMay 14, 2018NETGEAR Employee Retired
Hi mondofresh,
I have forward your issue to my internal team and they will contact you as soon as they can. :]
- Jason N
- ArodiDJul 11, 2019NETGEAR Expert
Hi mondofresh ,
Can you try holding down the factory reset button for longer than 5 seconds? Hold down until you see a change in the LED's then let go and see if that forces a factory reset.
Arodi
Community Team
