mondofresh
May 01, 2018Initiate
Problem with LB1120
My LB1120 on Verizon has been working fine for the past 3 months. Last week the unit stopped working.
Here is what I'm seeing:
Solid amber power light
The green signal strength bars are lit...
Blanca_O
Jul 18, 2019NETGEAR Employee Retired
Hi mondofresh
We just want to check if you still have issues with your LB1120. We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Blanca
Community Team
fjammer
Jul 25, 2019Initiate
I have the same problem. We have four LB1121 lte modems and one stopped working. Power light is amber. Then 1st, 3rd, and 5th bars are lit while 2nd and 4th bars have no lights. We tried switching sim cards and carriers between this modem and working ones and seems like the problem is limited to that specific modem.
Like the OP mentioned I have the same problem where I cannot get to 192.168.5.1 and reset button doesn't do anything. I think it's dead.
- KrisNeumanDec 06, 2019Aspirant
I have both a 1120 and 2120 I recently purchased through Amazon.com. I am having the same issues for both of these devices. I cannot access 192.168.5.1. What can I do?
- Blanca_ODec 11, 2019NETGEAR Employee Retired
Hi KrisNeuman
Please describe your network setup when you try to access 192.168.5.1. Kindly check the computer's IP Default Gateway if it is 192.168.5.1. If not, please use that to access the settings page.
Blanca
Community Team
