directs
May 19, 2018Aspirant
CM500 download speed reduced.
My ISP is Wowway and I am using a CM500 router. Download router speeds were fine (100+mbps) for several months. All of a sudden speeds dropped to 20 mbps. Upload speeds are fine. Wowway says ther...
JasonN
May 21, 2018NETGEAR Employee Retired
Hi Directs,
Thank you for posting in the community. NETGEAR has already replaced your device and is still having the same issue. They also said that the firmware is provided by your ISP. Is there a reason why your ISP is not giving you the firmware? If you refer to the support page of the CM500, under firmware. It says that the firmware is pushed out through your ISP and not from NETGEAR.
Please let me know. :]
- Jason N
JasonN
May 22, 2018NETGEAR Employee Retired
Hi directs,
Thank you for your response. Have you tried performing a factory reset on your modem? (holding the reset button on the back of your device for 10-15 seconds)
Is the download speed reduced for wired and wireless connections?
Can you please PM me with your firmware // PRI # // Sku # // etc. to me.
Please provide your contact information.
Thank you. :]
- Jason N
