JinTu
Aug 26, 2021Star
LM1200 repeatedly dropping link
I recently purchased an LM1200-100NAS to serve as an LTE failover connection for my homelab and noticed a strange issue while setting up my pfSense-based router to use the LM1200 as a secondary WAN c...
JohnPeng
Sep 22, 2021NETGEAR Expert
GeneK7087 wrote:
Could you please provide a link to the new firmware file that I can download manually as I can not find it on the website download page. Thanks.
The latest release has been posted online for OTA FW upgrade. You can do a manual FW upgrade check to have your device upgrdaed to the lates.
If you have any issue for upgrading your device, please let me know.
Thanks
GeneK7087
Sep 22, 2021Aspirant
I had the router connecting with the SIM from Verizon that I had from previous router. But since the port forwarding wasn't working, I tried to do the firmware update. The router would just fail trying to look for the FW update. No explanation in the message other than to try again later. Since I had already switched the router from bridge to router mode, I tried reseting the router to factory settings and was going to switch the IP version from v4v6 to just v4, however, after doing the factory reset the router would then no longer make a connection to Verizon. So I can not even attempt to have it try to look for the firmware update. Thus, I need a link so that I can manually download the file and upload it that way to the router. When I searched on the Netgear website for the firmware it says there is no update available. So again I ask, could please just post the direct link to the download so that I can manually download the firmware. Thanks!
