JinTu
Aug 26, 2021Star
LM1200 repeatedly dropping link
I recently purchased an LM1200-100NAS to serve as an LTE failover connection for my homelab and noticed a strange issue while setting up my pfSense-based router to use the LM1200 as a secondary WAN c...
SomebodyInGNV
Aug 28, 2022Guide
Verizon does not permit connection in bridged mode.
The modem cannot connect in bridged mode while the WAN power is active, then switch to router mode when it falls back to the mobile network. Apparently, if you need Verizon (or Visible) the only choice is to use the modem in router mode.
While not ideal, that's acceptable to me. My primary use of the modem is for Internet access while traveling. My brief experience is that it stays connected at a decent speed when in router mode.
Tacopilot
Aug 28, 2022Aspirant
I’m going to see if this unit works any differently.
InHand Networks IR302 Industrial Iot LTE 4G VPN Router, 4G LTE Cat 4+ Wi-Fi, Dual sim Card Slots, Management by Cloud Platform, DI/DO Port, Support AT&T, T-Mobile & Verizon https://a.co/d/ioTgo2w
