JinTu
Aug 26, 2021Star
LM1200 repeatedly dropping link
I recently purchased an LM1200-100NAS to serve as an LTE failover connection for my homelab and noticed a strange issue while setting up my pfSense-based router to use the LM1200 as a secondary WAN c...
Sireone
Sep 17, 2023Aspirant
Thanks, I know that the workaround works...but it's still what it is, a workaround. I need to be able to access my services (IP Cameras, etc.) while failed over to VZW. Does anyone know why this is happening in bridge mode?
p4r4ll4x
Sep 21, 2023Aspirant
I see the same problem here. I hope this gets fixed.
Set to Routing mode and disable DHCP is NOT a good solution since you introduce DUAL NAT, that is an unacceptable solution.
