Grapsen
Feb 19, 2024Initiate
MR6150 APN error 512 and intermittenly not finding sim
Hey, I have the Nighthawk MR6150 and it worked pretty flawlessly for a couple of months. But recently now it started getting the APN 512 error maybe once a day, but now it wont really stay on longer ...
felickz
Jul 15, 2024Initiate
Same issue, same behavior.
Worked fine one day, woke up next day and now can't find sim. Restarted 4 times and now it found it but only lasted for an hour. Error 512 in the UI.
Two other sims I have from same provider seem to work fine.
Blanca_O
Jul 21, 2024NETGEAR Employee Retired
Hi felickz,
I have sent you a message. Please check your inbox.
Blanca
Community Team
- Scottylad1903May 30, 2025Aspirant
Hi Blanca
i have the same problem as above please message me also
regards
scott
