Lenoom
Feb 27, 2019Tutor
Nighthawk M1 4g blocked by career
Now and today The company STC has blocked 4G with nighthawk m1 All type of network band of 4g, alot of people have this device they can use only 3G band Which is very slow , behave of other ow...
Blanca_O
Feb 27, 2019NETGEAR Employee Retired
Hi All,
We will check on this. We will get back to you guys for any updates.
Blanca
Community Team
Nabil_A
Mar 07, 2019Aspirant
After several attempts to avoid the blocked there is only one solution provide a special tool to change IMEI for MR110 and be under the control of the NETGEAR by some tools, If there is no radical solution I will sell the router and buy another router supported.
- aaalaaaMar 07, 2019StarNo one will buy it from you now 😥
- Abdul_3zizMar 08, 2019Star
Still the STC service provider blocked the NETGEAR MR1100-100EUS and restrict the bands to B40 only!!! netgearsupports
Please try to communicate officially with STC company to get their feedback from you as company
kindly check the attached!
