eip618
May 04, 2017Aspirant
Nighthawk M1 rebooting randomly
I got the Nighthawk yesterday. It is randomly rebooting itself even though it is connected to a consistent, correct voltage power source and will reboot whenever it feels like it. I assume this is a...
poiter
Oct 26, 2017Aspirant
Update:
First unit was evaluated by my local Telstra store and found to be faulty.
They had intended to observe for themselves and then do a factory reset but were met with reboots and did not proceed further.
Fortunately, Telstra made the choice to replace with a new unit. I would not have expected less as the first unit malfunctioned immediately and I only had it 2 days.
I have not sighted any unexpected reboots in the new unit and all seems to be functioning perfectly. Fingers crossed.
It is a great device when working properly, but I did some searching online and given the number of reports of this unit rebooting/restarting, there must be a persistent fault/issue with the build quality of the units.
Ray2017
Nov 15, 2017Tutor
My nighthawk Mr1100 keeps rebooting randomly as others have found .
I have noticed (I move address often) it is much worse in a strong signal area.
In a very strong area it could be constant making it unusable, in a weak area 15 munutes to several hours before a re boot.
Please get the technicians onto this.
- poiterNov 15, 2017AspirantRay2017 i would suggest that if you are able to, return your unit for replace or repair. My unit was faulty regardless of location, and it seems like yours may be too.... just a change of frequency.With my faulty unit, i kept a diary for a day of all the times the unit rebooted iteself and also took a video on my phone showing it happening. An evidence trail such a diary of reboots will hopefully work in your favour, as it did mine. Goodluck
- Ray2017Jan 17, 2018Tutor
Have taken the Nighthawk back to Telstra who sent it on to Netgear who returned it saying no fault found. The first time back it took 10 minutes to reboot itself, the second time it came back sying no fault found I got Telstra to send it back straight away without taking it home, the third time back it came home again and took 45 minutes to reboot then another 8 then another 28 minutes.
What kind of cursory check do they do? Not good enough!
- poiterJan 17, 2018Aspirant
Ray2017, i hear your frustration. Not good enough of Netgear or Telstra - this seems to be an issue with some of the units. As I said in my previous post, i took a copy of list of times, whenever the unit dropped out. I basically left the unit in front of me when i was working and jotted down the times over a day. I hope that if you can keep such a record, if netgear dont come up with the goods, then put it back to telstra and if they dont play, consumer affairs. Written evidence and a diary of events will hopefully help. Good luck.
- winger13May 17, 2018Guide
Mine started rebooting like crazy the past few days after a couple of months of no issues. I will look into where it is caused by being near a string signal or particular frequency(s). Frustrating as heck.
- Ray2017May 17, 2018Tutor
I sent mine back to netgear 4 times via Telstra (Australian service provider) and 4 times it came back with no problem found (cant have been looking very hard).
I filed a complaint with Telstra and they replaced it for me, so far no problems with the replacement 2 months on.
- winger13May 17, 2018GuideThanks for the downer, lol.
Did you ever isolate what was it was not the cause of the reboots? I mean the unit's bad, but what triggered the reboots?
