kdebauch
Mar 16, 2018Aspirant
Nighthawk M1 with Arlo Base Station
I recently recieved this hotspot router from AT&T. When they sold it to me they sent me a data sheet which said that it could be used as my Arlo base station. I have tried everything to figure out ho...
- Mar 27, 2018I updated the firmware and after a brief struggle, managed to get all of my cameras synced and working with the M1.
kdebauch
Do you think it is faulty? I wondered if that were the case, but AT&T told me that was normal for the port to not recognize any connections on the M1. I have never owned one before, so I have no way to confirm or deny this. Sucks that this got moved to the wrong section of the forum!
jguerdat
Mar 16, 2018Guru
I woulda thunk the port would be active but anything is possible.
Repost in the appropriate forum and just leave the Arlo-specific part out or at least reference that any device, including Arlo, can't use the port.
- JasonNMar 19, 2018NETGEAR Employee Retired
Hi kdebauch,
Sorry for the misunderstanding. I was thinking that all your other devices could connect to the M1 but your Arlo system couldn't.
Let me look into the issue on the faulty Ethernet port and will get back to you. :]
- Jason N
