watkincm1's avatar
Apr 20, 2020
Re-opening LB1120 Bridge mode issue?
Issue:  LB1120 in bridge mode refuses to be transparent - continues to assign IP addresses to my Linksys router and preventing port forwarding/DDNS set up.  My router believes its network IP address ...
  • fflukeh182's avatar
    fflukeh182
    May 11, 2020
    The problem is not with the modem or bridge mode. Your carrier is using CG-NAT or carrier grade NAT. Unless you can convince your carrier to give you a static IP you'll continue receiving a private address from your carrier. This is common practice with cellular providers. The other option would be to use IPV6 if your carrier supports the protocol.
