hairball96
Jul 04, 2018Aspirant
Wifi extender or repeater for MR1100?
What do I need to extend the range of the wifi signal on the MR1100, a wifi extender or repeater? Model recomendation of extender or repeater?
Just trying to get better coverage when using at home...
hairball96
Jul 08, 2018Aspirant
Thank You!
I tried hooking to my old router via the ethernet port before posting this question but didn't take all the steps you described and of course it didn't work. Also, when I looked at the MR1100 manual it sounded like the ethernet port was only for a wired internet source to offload the cellular device, so I concluded the only option was some type of wireless device. Thanks again!
UK-based
Jul 08, 2018Luminary
You're very welcome! The only problem I had was that the Ethernet port on the MR1100 went into standby mode from time to time due to lack of activity - this required the power button to be tapped in order to wake it up again. However, the latest firmware release has an option to Disable the Ethernet Standby mode, which means that it's always on. I'm running my MR1100 without its battery, using an upgraded QC 3.0 mains charger (the MR1100 is actually equipped with a QC 2.0 chip but QC 3.0 chargers are backwards compatible). The 2A charger that was supplied with the MR1100 provides insufficient power to run the MR1100 without its battery - it reboots when under pressure.
If you need any more help setting up your old router as an access point, let me know - I might be able to help.
