jprobins007
Feb 18, 2025Tutor
Reccomendations Sought for Cellular Modem (standalone or bridge mode available)
I am planning on adding failover and load balancing to my networking setup. I am using a Nighthawk RS700 as the router and a TPLink 707 as a bridge solely for its failover and load balancing features (i.e., with its router features disabled). I am looking at T-Mobile cellular as the failover bandwidth source. To do this, I cannot use T-Mobile's equipment, because they use an integrated modem/router and the router functions cannot be disabled. I am looking at the Netgear LM1200, which would fit the bill perfectly, except that, per the website description, throughput seems to be limited to 150Mps. I would prefer something that will allow for more bandwidth, but essentially everything I find has an integrated router. I can live with the integrated router provided I can disable it/utilize bridge mode and not have it interfere with the "real" router. Any suggestions or opinions on the LM1200 or a more robust option would be greatly appreciated.
P.S.--I just cannot see spending the money for the $800+ cradlepopints I came across.
- rcpaxLuminary
the 150mbps is the throughput of what? LTE modem (WWAN) or LAN? for t-mobile I can recommend the MR6550 or MR6150. You can do IP Passthrough which is the closest you can get to a bridge mode on these devices. LAN speeds on these devices can go up to 2.5gbps.
RCPAX: I guess I was speaking very generally. The material on the LM1200 states it supports "internet speeds up to 150Mbps". I am guessing that limitation derives from it being 4G instead of 5G.
- rcpaxLuminarysounds like you’re looking for better speeds. of course for mobile internet that would be very dependent on location. but the MR6150 woild be the cheaper option of the 2 and it is 5G capable. plenty of bandwidth when used with tmobile.
