copz1998
Jul 23, 2022Initiate
Reconnect to Device MR60 and T-Mobile
I recently moved away from Comcast/Xfinity Internet and hooked up with T-Mobile Home Internet. It works great. My old system includes two MR60 units mesh system, which also works gr...
Jul 23, 2022Guru - Experienced User
1. make sure icloud relay and private mac/ip address is disabled.
2. go into the tmobile gateway and put the netgears IP address into the tmobiles DMZ
copz1998
Thank you!
Turning off iCloud relay did the trick. I also did an uninstall/reinstall of the app. All good!
Thanks for the help!!
