slimbo's avatar
slimbo
remove NAT
I have a UniFi USG that I want to use with the Nighthawk MR1100, which does works, but I need to be able to build a site-to-site VPN tunnel and since the NightHawk MR1100 is doing NAT on the single Ethernet port, it won't work. Is there a bridge mode or other way to get it so that the device on the network LAN will get the public IP address?
  • plemans's avatar
    have you tried putting the Unifi's IP address into the MR1100's dmz.
    • slimbo's avatar
      slimbo
      No, but I will try it now. I was also thinking of maybe port fowarding just opening it up wide since it's going to connect to a hardware firewall anyway
    • slimbo's avatar
      slimbo
      I enabled the DMZ and then put my firewall WAN port in it, but that did not work ... I looked at port forwarding and there's no option to just allow all, any any. I am guessing that possibly this is not going to work.
      • plemans's avatar
        did you use the ip address for the firewall?
        What actual device is it?
