Kevana
Jul 13, 2018Follower
Replacement Battery for Nighthawk M1 (MR1100)
Where can I buy a replacement battery for this model
- Jul 23, 2018
If your provider is AT&T, I posted previously that they now have it in stock. I'm not sure how much they would charge, but they do provide replacement batteries for free (assuming it's a hardware problem, like when the unit completely discharges a battery to the point that it won't recharge) as part of their warranty service afaik.
schumaku
Jul 14, 2018Guru - Experienced User
As discussed before -> https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/Replacement-Battery-for-Nighthawk-M1-MR1100/m-p/1474755 - talk to your ISP which is offering the M1/MR1100, your re-seller offering the retail version of the M1, or challenge a search engine, Ebay, AliExpress, ...
PS. Completely unrelated to the Nightawk Pro Gaming Switch forum thread.
