zephyr99
Jun 19, 2021Aspirant
reusing mr1100 firmware update
i have a couple mr1100 units. and the 12.06.39 update is available. does someone know the method to use so that i can download it once? the auto firmware update does not seem to tell me where the file is located. i would like to do a manual firmware update on the 2nd unit.
> Once is usually enough.
If you actually read the two posts, then you might notice that their
questions are different.You may have done this already. I can't tell from your message.
