mclarke21's avatar
mclarke21
Rogers Air Card 330U on Mac OS High Sierra
I upgraded to High Sierra on my Mac and now the Rogers Air Card 330U doesn't work anymore.
Wondering if anyone has this issue and knows a fix for it.
Thanks,
  • JasonN's avatar
    JasonN
    NETGEAR Employee Retired
    Hi mclarke21,
    I just wanted to check in with you and see if your issue has been resolved. Please provide the information requested above if it hasn't yet.
    Thank you. :]
    - Jason N
    • mclarke21's avatar
      mclarke21
      Hi Jason,
      Thank you for your reponse.  The device was working fine prior to updating to High Seirra.  It also works on a Windows machine.  I will double check the firmware version.
      mclarke21
