Quata
Aug 12, 2018Follower
setting up wifi password on WGR614v10
i reset my router & now i cant change wifi password. i need help getting the routerlogin.net screen
- Aug 13, 2018
Hi Quata,
Welcome to NETGEAR Community!
Using a computer that is connected to the network, open browser and access routerlogin.com or routerlogin.net . On the main menu, select Wireless Settings then you can change the SSID and passphrase.
Blanca
Community Team
Blanca_O
Aug 13, 2018NETGEAR Employee Retired
Hi Quata,
Blanca
Community Team
