Jim1648
Apr 21, 2023Initiate
Should I Go With A MR5200 or MR6150?
I use both AT&T and T-Mobile data lines.
I want a hotspot that will do 5G with either AT&T or T-Mobile.
It looks like the Netgear MR5200 or MR6150 might be good choices.
What are the differences between the two of them?
If they're roughly the same price for you, go with the MR6150. Faster 5ghz speeds and a newer chipset.
There's a pretty solid review of the M5 vs M6 on dongknows.
https://dongknows.com/netgear-nighthawk-m6-mobile-router/
- JohnPengNETGEAR Expert
Definitely go with MR6150. It supports more 5G features than MR5200 and faster as well.
Thanks
