JoelSch
Nov 11, 2021Follower
Sim not recognized
I just got my Nighthawk mr1100, I’m trying to use a Verizon sim from another hot spot but it says sim not installed. I re-installed it couple times turned the machine on and off even tried to reset but it doesn’t help.
- JohnPengNETGEAR Expert
Please check whether the PINs of SIM connector are not deformed. You can carefully raise them if they got flattened during to previous uses.
Thanks
