burbello's avatar
burbello
Simcard not recognized into the tray
Hi,
I have recently bought the 4G AirCard 782S and used a while. However once I had to change the simcard and I noticed an issue to take out the simcard from the tray, I have put a bit strength and I have possibly bent the small pieces of contact that touch the simcard.
From that time, no matter the simcard I put in, it does not recognize as inserted.
It is possible to fix by myself? or, can you share the location of a support store to fix it?
Thank you, Alexander
  • Posted in the wrong forum. This is for Nighthawk Routers. Doubt anyone here can help, nor move your post to the proper forum.
    • burbello's avatar
      burbello
      Sorry for the misunderstanding, but this is the only forum I see other questions being posted.
      I can't find other category that belows to my issue, that's why I posted here.
      Thanks.
      Alexander
