Giovanni04's avatar
Giovanni04
Simultaneous dual band portable router
I just bought a TP-Link Archer MR600 from amazon, but hasn't arrived yet. I'm thinking if there is either a portable router or hotspot, with at least the same performance, at a fairly similar price, but with a built-in battery and possibly smaller. Actually I'm not sure if MR600 supports simultaneous dual-band, how can we know that?
I'm going to use it with a 4G sim card to work on my laptop at 2.4ghz, which doesn't support 5ghz, and play online on my ps4 at 5ghz.
Thank you for your answer
Giovanni
1 Reply
