Flue
Sep 27, 2017Aspirant
slow wifi (.4 mbs ) ok when tethered nighthawk m1100
- Oct 05, 2017
Thankyou for your assistance.
A simple factory reset and renewing settings solved my wifi speed problem.
DarrenM
Oct 02, 2017Sr. NETGEAR Moderator
Hello Flue
Can you give some more detail on the issues you are having.
DarrenM
- FlueOct 04, 2017Aspirant
Thank you for your interest
simple problem.
when connected via wifi i test speed of Ping 430 ms download 0.4mbs.upload 0.8 mbs. testing to melbourne telstra.
when connected via tether i get Ping 25 ms download 64.6 mbs upload 48 mbs,
this suggests that wifi is not working correctly.
Does anyone have a solution?
- FlueOct 05, 2017Aspirant
