tiffanieee56's avatar
tiffanieee56
SSID Nighthawk M6 model MR6110
Hi...when you hide your SSID how would I now get to it to sign in and use it?  Do you go to where it says "other networks" and put it in manually?
Also these forums are very new to me so if I mess up please forgive me....
I got a response from a prior question and I dont know how to get back to it to thank that person for helping me....dont mean to confuse anyone.  Thank you!
  • schumaku's avatar
    schumaku
    yes. Type the network name manually, as it is made hidden and can't be selected therefore. Curious: What was the ide behind hiding the SSID? It's cumbersome for connecting new devices, and it does not add any security.
    • tiffanieee56's avatar
      tiffanieee56
      I think my neighbor hacks me ...but I can never find her...is there one simple answer to secure my network...she is a cheap scrounging thief and she is better at this than me apparently...I cant take it anymore...the other thing is is there a business that I could hire to educate me on all this stuff?
      • plemans's avatar
        You don't need to hide your ssid. In fact, the peop;le who are going to be the ones getting on it, can find it easily enough. You just need a good ssid password that she can't guess using wpa2/wpa3 (if the mr6110 has wpa3)
