Retired_Member's avatar
Retired_Member
Mar 04, 2020
Support for M2
Hello everyone,
We have a number of these devices in our environment spread across the state, but have no capability to manage and or update them centrally.  While they are more of a consumer device, is there any plan to enable the centralisation of these?
Some things that we would love to do from a central location:
  • Push config changes out.
  • Fireware updates
  • Whitelist updates
Without this the devices need to be recalled or never updated, which with security is not ideal.
Failing this, does anyone know of a portable mobile hotspot that is enterprise manaaged, seems to be a hole in the market.
Cheers
John
  • schumaku's avatar
    schumaku
    Blanca_O please (also move to Mobile Routers, Hotspots & Modems section, thank you!).
    • Retired_Member's avatar
      Retired_Member
      So know this has moved out of the insight forum, which is what the question was about, does anyone from Netgear have a comment?
      • schumaku's avatar
        schumaku
        Insight is a SMB BU product, while the hotspots/MiFi routers/modems are consumer devices. I've requested moving it away because there is neither support for these devices in Insight not are there any plans to integrate as far as I know as a non-Netgear person.
        A feature request for a mobile management platform does belongs to a different BU. Insight or any other implementation might be the possible platform. On my opinion, there might be not enough feature and capability overlap - similar for example Orbi Pro where adding it into Insight opened up discussions on feature gaps of the device side.
