Albo3li
Aug 29, 2018Guide
Supported bands on the MR1100-1RDMES model?
Hello, i have tried to search everywhere about the Nighthawk M1 MR1100-1RDMES model and what bands does this model use or what LTE Carrier Aggregation does it support but i can't find anything!
Does anyone can help? Thanks
Albo3li MR1100-1RDMES supports the following bands:
4G LTE Bands: 1, 3, 7, 8, 20, 28, 38, 40 and 41
3G WCDMA Bands: 1, 2, 5, and 8
As far as CA combos go it support the bands that Ooreedoo Kuwait would have requested from Netgear.
MR1100-1RDMES is a carrier specific model made for Ooredoo -> Product Datasheet (MR1100-1RDQAS) for Ooredoo
All MR1100 variants offer 4G LTE Advanced Category 16 with 4X4 MIMO, 4-band Carrier Aggregation and LAA.
As it's a branded device, be aware a SIM lock might be in place.
- Albo3liGuide
The one you showed is another model MR1100-1RDQAS and every model support different bands and CA + in my country they use 800 band and the model you showed doesn't support it..
There is alot of models (MR1100-1TLAUS/MR1100-100EUS/MR1100-100NAS) and others so i need to know what model bands does MR1100-1RDMES uses
Afraid, sorry for the mix-up. I can't locate any datasheet for the MR1100-1RDMES (which is also a provider branded unit).
In which country is your demand for the MR1100?
- Albo3liGuide
WOW.. is it really that difficult to answer a question about a product that created by netgear on a official netgear forum?
- schumakuGuru - Experienced UserAs a non-Netgear employee: The specific product variant you ask for is manufactured by Netgear, but a typical carrier specific branded model not sold and supported by Netgear.
- Albo3liGuideHow specific branded models are not supported by Netgear when the Nighthawk M1 models for AT&T, EE and Telstra are listed on? https://www.netgear.com/support/
If Netgear created and made a specific branded models for any carrier they must know what bands are support for each model and i'm still waiting for an answer that i think i will never get..
