DavidIMcIntosh
Sep 19, 2015Aspirant
technical details on external antennas
I will be using my AC763S in a remote location that requires an external antenna to get a signal. I know the exact towers I will be connecting to, and I know the exact frequencies (LTE band 1 and/or...
Ernst1948
I found some good info on the site of Pointing (http://mybroadband.co.za/): blogs and forum. My understanding is that the two extrenal antenna connectors of the AC785S etc. are for MiMo. So you should have two antenna's, each capable of working in both the up and down frequencies. Mount them with 90 degrees polarity difference and then look for the optimal orientation \, e.g. 0 + 90, 45 + 135 or something else.
- DavidIMcIntoshSep 19, 2015Aspirant
Thanks. Thats exactly what someone else on another forum said, so your answer coroborates that.
