Hugh_B's avatar
Hugh_B
Follower
Jun 29, 2016
Touchscreen security
Hi,
Is there a way to password protect (or prevent access) to the touchscreen of the AirCard 790S device ?
I have changed the administration login password on the web page configuration for the device (from the default "admin") to prevent access to the setting on the web page, but even if I hide the SSID and Password from the front screen of the device, anyone can just access that information by going into the settings function via the touchscreen of the device.
Cheers.
1 Reply
  • Is there anyway to lock the touchscreen, or disable the ability of changing it from the touchscreen... This totally unsecure...
