Danny212's avatar
Danny212
TP Link TL-PA4010
In order to improve video conferencing ability in this Covid19 age, I dusted off a pair of TP-Links that are 4+ years old, connected one of the router's ethernet ports to one, plugged it in, then plugged in the other in a room that gets weak WiFi, and attached to my laptop with an Ethernet cable. It's all green on the boxes but is not showing up on my Windows 10 networks. Advice, anyone?
TP Link TL-PA4010
  • plemans's avatar
    Check the tp-link forum and not the netgear forum if you're using a tp-link device?
    do they work in the same room?
    • Danny212's avatar
      Danny212
      Oops, my bad, I assumed it was Netgear product because of how something was listed on my network list. Thanks, will look to TP
