astocker22's avatar
astocker22
Follower
Jul 10, 2018
turn on WMM
I bought the M1 to use for a work demo with WIFI phones, i already have a TP LInk and a proling which nativly support WMM.
I can't find anywhere in the settings for the MR1100 to enable WMM or APSD
1 Reply
  • Hi astocker22,
    My understanding was that WMM is generally "required" for 802.11n and 802.11ac data rates isn't it?  Do you have evidence that it is not already enabled by default?
    My iPhons 6s (AT&T) and Samsung S7 edge (Tmo) hapilly do wifi calling over the MR1100.
    -Jonathan
