Jantix
Aug 22, 2018Tutor
Unable to access ReadyNAS Duo v1
Hello all!
I hope this is the right place to post. I cannot find any better site.
Anyway: I have a ReadyNAS Duo v1, and suddently I cannot reach it.
The system says something about SM...
- Aug 24, 2018
Hi Jan,
This is off-topic in the Mobile Routers, Hotspots & Modems forum area.
Anyway, to keep your WIndows 10 system workable with your legacy ReadyNAS, open "Turn Windows Features on and off" in the Windows Control Panel (simply search for "Windows features" in the "Type here to search" field!). Under "SMB 1.0/CIFS File Sharing Support" enable both "SMB 1.0/CIFS Client" _and_ "SMB 1.0/CIFS Server". The later one is required since newer Windows 10 builds because of the NetBIOS host discovery and name resolution is part of the server.
Regards,-Kurt
schumaku
Aug 24, 2018Guru - Experienced User
Hi Jan,
-Kurt
Jantix
Aug 24, 2018Tutor
Thank you!
I cannot find "Turn Windows Features on and off" here. It's probably called something else in Norwegian, but nothing here that rings a bell. I will try to find out, however. Thank you!
Jan
